I recently changed my adress and since then, I'm experimenting problems with the internet connection of my ps4, the connection seems intermitent, every more less 5 minutes que connection es down (it's impossible to play online and use the play store). I connect my ps4 by cable, but the problem is the same with the wifi.
I read in this forum that is my IP in IP WAN starts with 10.xxx... i will have problems, and this is my case, it starts with 10.xxx....
Can you help me changing my IP adress to public?
Thank you!
Mauricio.
Meilleure réponse par Antoine L
Hello @poffs,
Is the issue on your PS4 only ? If that's the case, it might be an issue with your IP address. I changed it to a public address.
If you have this problem with other devices, I'll need more details to help you.
