Internet connection Etterbeek - no coaxial cable?
Hello :)
I am moving into a renovated apartment in Etterbeek, but according to the Voo website, it does not have a coaxial connection. However this is not true, as the previous tenant used proximus. Would it still be possible to change over to Voo?
Many thanks 🙂
Daria
Meilleure réponse par cosmos1999 5 octobre 2019, 19:17
The Proximus cable is not a coaxial cable at all , and is not in any way connected to the VOO cable network.
Unfortunately , it will not be possible to subscribe to VOO services without having first a VOO coaxial cable installed.
Le Plus de Roylion15 :
Etterbeek is a TELENET zone , thus VOO services are not available !
5 commentaires
Hello Daria !
VOO does not use the Proximus technology to deliver the necessary connection. It is therefore necessary to refer to the VOO website, there is unfortunately no possibility of using VOO in your new apartment, if it is written this way on the website ! 😞
Nevertheless, have a good evening !
May be you’re a bit wrong ....
Anyway, the problem is the same: the Proximus cable is not a Telenet coaxial cable .....
He need to perform a test with the adress of the appartement on the télénet site .... I’m pretty sure it’s available ...
