Box evasion remote control buttons
I have a box evasion that is less than 15 days old and I have problems already:
Some buttons on my remote control have no effect. In particular, I can use the arrows pointing above on the main round button (change Channels in a decreasing way) but I cannot Change channels in an increasing way because the arrow pointing down on my remote does not produce any effect. It happened several times and in some cases reinitiating the box solved the problem but this does not work anymore...
Any help?
Thanks in advance
Carolina
1 commentaire
hello cavila,
Are there others buttons that aren't working ?
When you push the "home" button and then hit the arrow pointing down, does it move in the menu ?
A colleague will contact you shortly about your remote control.
